Oil temp sensor for M84
Postby jwm on Thu Apr 21, 2016 12:32 pm
Hi
What 1/8npt oil temp sensors are compatible with M84
I only have a 1/8npt port available
jwm
Re: Oil temp sensor for M84
Postby Stephen Dean on Fri Apr 22, 2016 9:56 am
Any linear output pressure sensor can be used with the M84 as a custom calibration, if you have the voltage values for the high and low points of its measurement range.
We have preconfigured calibrations in the management program for TI/Honeywell sensors, as well as VDO senders.
Return to M84 ECUs
