What units are you using in the ECU? The dash assumes everything is sent in SI units so if you have your pressure channels in PSI then you will need to either change it back to kPa in the ECU or convert it in the dash.
In the Input Setup page, you select the units used for the Input by selecting the appropriate calibration. This is shown in the brackets in the name as to which unit is used.
M84 inputs.JPG (93.68 KiB) Viewed 13145 times
Stephen Dean MoTeC Research Centre Melbourne, Australia
