M84 REF/SYNC connector wiring
I have the un-terminated harness for the M84. From the ECU harness connectors there are two groups of wires for both the REF & SYNC sensors onto which I need to install a 4-pin female Deutch connetor. Each group contains a red (+), black (0V), white (signal) and a shielding wire. I'm assuming the shielding wire, if used, needs to be connected to the 0V pin. Is this correct? I'm using Hall Effect sensors for both REF & SYNC. When facing the male connector from the sensor with the latch on top, there is a white wire in the upper left and lower right corners. I'm assuming one of these is the signal wire but how do I determine which one it is? Sorry for the basic questions but this is my first Motec harness and I want to get it right.
