M84 with 4 + 1 REF trigger wheel?
Postby dionysus on Wed Jun 10, 2015 8:57 pm
Looking to fit M84 to a vehicle currently running an old Weber Alpha system, the trigger wheel currently fitted is this unit:
There is currently no SYNC provision on the engine, something I will be retrofitting for a single event trigger per cycle.
Will this 4+1 pattern be acceptable? I would prefer to fit a 36-1 or 60-2 disc, however - that would require an engine removal due to very limited access - something I am very keen to avoid unless essential.
Many thanks.
dionysus
Re: M84 with 4 + 1 REF trigger wheel?
Postby SprinterTRD on Thu Jun 11, 2015 10:27 am
Your answer is in the help file.
"Adjust" "Sensor Setup" "Ref/Sync" Highlight "Ref / Sync Mode" press F1 select general
Return to M84 ECUs
