looking for some input on where to put letter "B", Logic ground. Im taking it ignition signal is A1-4 ( 4 cyl). would "B" go to A10 or A11 or could it connect to batter negative, same as "D"?
Here is the connector pinout:
A - Ignition signal from ECU
B - Logic ground, connect to ECU ground
C - Spark wire ground, connect to cylinder head
D - Power ground, connect to battery negative
E - 12 volt power
ty
dean
