cop coils
cop coils
Postby harky on Mon Aug 04, 2014 2:53 pm
Me again with more questions
do I need an ignition module with the 4 cop s , for an Hayabusa gen 1 , the primary windings of the coils spec is 0.8 -- 1.2 ohms
my logic is the coils run off the oem ecu so the M84 should cope , the wire size to both is 20g ( ie from the oem loom and the motec m84 loom ) or looks the same dia to me
So thanks for any advice
harky
harky
Re: cop coils
Postby SprinterTRD on Tue Aug 05, 2014 2:09 pm
Your logic would cost you money in ECU repairs! You need to use a ignition module.
You should check the drawings section on the website how to wire the modules.
Re: cop coils
Postby harky on Tue Aug 05, 2014 6:50 pm
thanks
got that
will get a 4 coil ignition module
haky
harky
Return to M84 ECUs
