o2 sensor
o2 sensor
Postby harky on Thu Jul 31, 2014 10:37 pm
hi all
I am about to buy an O2 sensor to use with the M84 on an Haybusa engine
Of the ones I can use is their any "better"unit or advantages / disadvantages of one over another
so ---LSU 4.0 or 4.2 or 4.9 or NTK ?
thanks or any advice
harky
harky
Re: o2 sensor
Postby mstech on Fri Aug 01, 2014 10:21 am
Use either the LSU 4.9 or the NTK, don't bother with the earlier Bosch units.
mstech
Re: o2 sensor
Postby baselkwt on Fri Aug 01, 2014 3:37 pm
I have been using NTK on all my projects.
I would recommend the NTK if you are using leaded gasoline.
if you are using unleaded either the NTK or bosch 4.9 would be fine.
baselkwt
Return to M84 ECUs
