AT input temp parameters
Postby fordpop on Sat May 31, 2014 10:09 pm
Guys,
Sorry for another seemingly basic question, but a search revealed nothing really relevant.
I'm trying to set up a two wire engine oil temp sender.
I assume I can only use the AT inputs, but what parameters do I select for a temp input?
I also would like to set up a trans pressure sensor, so same question really would this be an AT input & if so, how do I set up the parameters?
fordpop
Re: AT input temp parameters
Postby WIDEMR on Sun Jun 01, 2014 10:25 am
Correct, variable resistance 2 wire temp sensors get wired into AT inputs, however you can wire them into AV inputs if needed but would require an external 1,000 ohm 'pull up' resistor to be wired between the input and 5v.
Pressure sensor would be wired into a AV input if its a normal 0-5v sensor.
What sensors are you wanting to use?
WIDEMR
Return to M84 ECUs
