Auxiliary output issue
I'm setting up a shift light using 4 Aux outputs which will drive 4 pairs of leds.
Aux1 will turn on at 4000rpm, aux2 at 6000, aux3 at 9000 and aux4 at 12000.
LEDs are permanently connected to ground and I was expecting the auxiliary outputs to bias them with 12v. Each led has a resistor (they're 4V leds).
My problem comes when I see that the only output that will send 12v to the LEDs is only Aux1. The other outputs will only send 2-3V. Reading the manual, I see that the only trouble could be the power consumption, but assuming that every led will consume just about 50mA, I don't think this is the problem.
Am I missing something? I just thought that all the outputs would work like aux1.
Thank you very much. Regards.
