HELP!!!! Brand New To Motec
Postby trucker on Sun Jun 23, 2013 7:23 am
I have a Motec M84 ecu and I have been reading everything I can find to educate myself on the features. For right now though I only need to know how to do two thing's and that's to check the air fuel lambda mixture and make adjustments if its rich or lean. My question is after I make a pass down the drag strip and plug my laptop in and open the ecu manager. Where do I look to check my lambda? And how do I adjust it if it's lean or rich? I want to keep my lambda between 0.80 and 0.85 any help will be greatly appreciated. Or how do I use the quick lambda feature? My lambda fuel table is setup. Thanks in advance.
trucker
Re: HELP!!!! Brand New To Motec
Postby stevieturbo on Sun Jun 23, 2013 8:38 pm
I guess reading the user manual is out of the question ?
http://www.motec.com.au/m84/M84downloads/
Postby Holmz on Mon Jun 24, 2013 12:46 am
With i2 or i2 pro one can look at the data.
Postby stevieturbo on Mon Jun 24, 2013 4:36 am
Assuming the ecu has access to the data you seek, and the ecu is configured to log that data.
Return to M84 ECUs
