M84 Pedal/Torque Maps
Hi There
I'm about to use another Ecu to control boost & driveablity maps which cannot be done with the M84 as it only allows one boost input,the probelm I have is that if I need to turn the boost/power down it will only go to the mechanical spring pressure which is to high for wet/damp conditions,I have a Rpm output, what I need the Tps signal from the M84. Can I output this to one of my spare AV channels, leaving the m84 to deal with only Spark & fuel also added a seperate T-map so it will effect become a stand alone system.
Many thanks if anybody can advise if this has been or can be done
Phil Collard.
Phil Collard.
