Can timing be set further BTDC than the CRIP?
With my 20yo 2-Group, which was wasted-spark & for which I wasn't using REF+SYNC, you couldn't set the ignition timing such that the cylinder would spark before the timing-signal the ECU was getting. Or at least, this was what I was told.
Looking at the M84, and I think I have this right, the CRIP is the number of degrees of crank rotation to TDC from the first REF signal the ECU gets after it's SYNC signal. So say CRIP is 40 degrees. Is there a limitation that I therefore can't set timing to 41 degrees BTDC? Or can the ECU know from the frequency of the REF signal that the next revolution would be 41 degrees BTDC and hence calculate such that the spark will be triggered 1 degree before that "first REF signal the ECU gets after it's SYNC signal"?
