Renault REF/SYNC
Mon Mar 19, 2012 8:51 pm
by bodom
Hello
Is there anyone who knows the settings for the flywheel of a Renault Clio Williams or generally Renault?
Thanks alot for all hints.
Stefan
Re: Renault REF/SYNC
Wed Mar 21, 2012 10:30 pm
by bodom
Is there no Renault-user or a specialist?
I can email the REF/SYNC-Capture if this helps. Unfortunately it's impossible to attach *.rsc2 in here.
Thu Mar 22, 2012 3:04 am
by BMWTuner
Hi friend.
I don´t have experience with Renault.. but, i have experience to work with much more exotic engines that i never find ready information regarding ref, sync and CRIP setup.. so, for me is usual this kind of situation.
If you tell me the engine code, the crank trigger wheel type, sync type (if you don´t know, take a picture of trigger point or disk in the camshaft or pulley), we can discovery together the correct sync/ref setup.
Regards,
Matheus
Thu Mar 22, 2012 3:11 am
by BMWTuner
now i see that you have a capture..
send to my e-mail:
contato@kolbercrank.com
Thu Mar 22, 2012 7:27 pm
by bodom
You've got Mail.
Thanks alot.
Thu Mar 22, 2012 7:40 pm
by stevieturbo
Arent most Renaults just a 60-2 ?
Scope capture should tell you quite easily.
Thu Mar 22, 2012 7:43 pm
by bodom
The newest one's yes, but the older ones, including the Clio Williams were 44-2 or better 44-2-2!?
Thu Mar 22, 2012 10:35 pm
by BMWTuner
I will only be in my shop tonight, so, i cannot open the capture now and also cannot open the MoTec software to check which modes are accepted.
But by picture, it is 44-2-2. First, we have to check if MoTec support this mode in software.
If not, i think is better to use different ref and sync trigger. You can fit some other Renault conventional 60-2 flywheel (check the bolt pattern and also clutch diameter) and fit a one tooth cam trigger. With this, you can run in conventional mode 7 in MoTec. Is very easy to arrange in this setup.
Wed Apr 04, 2012 1:22 am
by bodom
Dear BMWTuner
Thanks very much for your help. I appreciated this alot.
Now, the engine works wunderful and has more power than expected.
Thanks,
Stefan
