Can M84 be connect to SDL sport Dash ?
Postby Fueltank-Tai on Tue Sep 06, 2011 2:41 am
Dear Motec:
How are you? I am installing M84 to GTR 34 with SDL Sport .I found SDL sport dash sofeware CAN communication setup have not M84 so i have question . Can M84 be connect to SDL sport Dash ?
Thank you so much.
Tai
www.fueltank.hk
Fueltank-Tai
Re: Can M84 be connect to SDL sport Dash ?
Postby MarkMc on Wed Sep 14, 2011 6:21 pm
Yes, the M84 can connect to the SDL. The communications template for the SDL should instal with the M84 software, if it does not just let us know at support@motec.com.au.
Postby Mazi on Wed Sep 14, 2011 10:39 pm
You must install SDL3 manager. Then you can copy M84 template file from //SDL3/comm directory to //dash/comm directory. And you will find it on the SDL template list...
Mazi
Postby MarkMc on Thu Sep 15, 2011 6:02 pm
With SDL3 in stalled you copy the "MoTeC M84.CC7" file from
C:\Program Files\MoTeC\Dash\Comms Setup
to
C:\Program Files\MoTeC\Dash\Sport Dash Manager 1.6\Comms Setup
I have attached a slightly newer version of the comms template.
MoTeC M84 v2.CC7
(8.12 KiB) Downloaded 1257 times
Postby Fueltank-Tai on Sun Sep 18, 2011 2:15 am
Dear MarkMC:
Thank you so much.
Fueltank-Tai
Return to M84 ECUs
