M84 for 2 rotor
M84 for 2 rotor
Postby wankelparts on Mon Aug 08, 2011 2:00 pm
ok just got my m84 for my rotary engine first ? do they come from factory set up for primary injectors and secondary injectors second where can i find on how to wire up the s4 s5 distributor to the ecu sync and ref lets start there thanks for help and if any body have a base turbo map set up that would be a great start wankel boy with m84 :shock:
wankelparts
Re: M84 for 2 rotor
Postby MarkMc on Thu Aug 11, 2011 5:40 pm
The M84 needs the Hi/Lo injection upgrade to run the staged injection.
If you do a search on the website for Mazda Rotary there will be a drawing you can download that suits the 24tooth magnetic distributors.
Re: M84 for 2 rotor
Postby wankelparts on Mon Aug 22, 2011 1:16 pm
ok seting up my ref/sync set up on my m84 this is what i have so far
Re f/Sync mode value 2
Crank Ref teeth value 12
Tooth Ratio this one not sure what to put please help
Ref sensor type value 2
Ref Sensor edge polarity value 0
Ref Trigger voltage value 0.0
SYNC SENSOR TYPE VALUE 2
SYNC SENSOR EDGE POLARITY VALUE 0
SYNC TRIGGER POLARITY 0.0
SO IF SOME ONE CAN LOOK AND TELL IF IAM CORRECT THIS FOR A MAZDA S4 2 ROTOR
THANKS FOR HELP
wankelparts
Re: M84 for 2 rotor
Postby MarkMc on Wed Aug 31, 2011 6:00 pm
I think if you watch the Ref/Sync webinars you may be able to answer your own questions. :)
Return to M84 ECUs
