Little help with M84 spec /options please
Hi all,
First post on the forum so be gentle with me
I'm fairly new to aftermarket engine manegment but I do have a good understanding of fuel injection and the operating principles.
I'm provisionaly looking at using an M84 as it seems to have everything I would ever need for my 4 cylinder turbo application. What I need some help to understand before I buy and indeed what to buy is the following ;
A> Looking at the wiring diagram the M84 has a single dedicated EGT input on pin B20, to use this input with an EGT sensor is a seperate thermocouple amplifier box needed or can the sensor be wired directly to the ECU ?
B> I'd like to run four pen coils (COP) in a CDI system obviously one per cylinder, my question is can these be wired directly to the 4 ignition outputs on the ECU or do I need another CDI / ignition amp box ?
C> Can the ECU be configured to display A/F ratio instead of Lambda ?
Thank you in advance,
Richard
Richard
