m48 CAN CONTROL AN AUTO TRANSMISSION
Postby esvilopez on Tue May 10, 2011 8:02 pm
HI I'M NEW HERE AND I HAVE A QUESTION I HAVE A 95 TOYOTA SUPRA TT AND MY TRANSMISSION IS AUTO, WILL I BE ABLE TO USE A M48 SINCE IT WAS INSTALLED ON A SUPRA BUT IS A 6 SPEED THANKS FOR THE HELP
esvilopez
Re: m48 CAN CONTROL AN AUTO TRANSMISSION
Postby diamond1676 on Fri May 27, 2011 4:37 am
i think, you need to install the m48 and factory ecu together if you want to drive with auto transmission. it calls piggy back...if you drive of manual transmission, then you can use m48 individual, take off the factory ecu...it is going to be well.... :D
diamond1676
Return to M84 ECUs
