M84 on SR20DET VVT
i am just instaling M84 on my Nissan Silvia S15 equped with Variable Valve Timing. We know that the M84 does not support Variable Valve Timing. But if my informations are not bad, the VVT on S15 is just ON/OFF function of one valve. Is it right ? So my idea is to use Auxiliary output as an signal for the valve, and open it for some specific window of RPM, is it wrong idea?
Also want to ask about some "startfile" for my aplication. This is not about maps, it is just about setup of all the sensors, triggers, compensations etc... Good startup file will save me so much time.
Thank you
PS: For example included startfile on Subaru N14 ecu has worked perfect for me!
Thank you
