How to set up the IAT sensor and ET sensor
When the engine is off,the two sensors'outputs should be early same.
But the IAT's output is 13.7℃ but ET sensor' s is 15.7.
How should I setup the two sensors?
The same thing has happened to the MAP and FP without fuel.
Thank you!
Thank you!
