Can a TCMux or an SDL3 module work with M84 ECU?
PostPosted: Thu Mar 10, 2011 10:11 pm
by Vassili Wang
Can a TCMux or an SDL3 module work with M84 ECU? I've found that the software didn't allow users to configue the channel of Wheel Speed. And there is only "SLM" in the "communication" menu.
Thanks ~
Re: Can a TCMux or an SDL3 module work with M84 ECU?
PostPosted: Mon Apr 04, 2011 3:08 pm
by OmarK
You are correct the inputs are fixed in the M84 and therefore you cannot use a TCMux, is there is a reason you need to use the TCMux?
An SDL3 can definitely be connected to the M84 via CAN, there is a fixed list of channels that is being sent. To view the channels in the SDL3 Manager select the MoTeC M84 CAN template.
PostPosted: Thu Aug 04, 2011 12:39 am
by gts_215i
+1 request for the TC Mux input enabled
4 digital inputs -
1 x TC Mux (with the TC on/off function)
1 x GM fuel composition sensor
1 x A/C Request
1 x Clutch Switch (Launch / Traction Control)
PostPosted: Wed Aug 10, 2011 6:18 pm
by MarkMc
The A/C request and Clutch can go onto switched inputs. :)
