M84 and PDM
Thu Jan 20, 2011 6:43 am
by Martin
Is it at all possible to have an M84 communicate with a Motec PDM?
What options are there to interface these two devices?
Re: M84 and PDM
Thu Jan 27, 2011 4:01 pm
by MarkMc
Hi Martin,
We are currently trying to work this one out. Need the best overall solution.
Re: M84 and PDM
Fri Jan 28, 2011 5:35 am
by Martin
good news! thanks
Re: M84 and PDM
Mon Jan 31, 2011 4:40 pm
by Motorsport Eng.
Hi Mark,
we would like to have the M84+PDM communicating as well, so thanks for having a look at...
Regards
Re: M84 and PDM
Mon Feb 14, 2011 3:30 pm
by MarkMc
Good news,
I currently have the latest test software with a CAN ouput that works for the PDM (and VCS). The channels are:
Ground Speed
RPM
Gear
Efficiency
TPS
Engine Temp
Air Temp
Oil Press
Fuel Press
User 1
User 2
Status Group 3
Re: M84 and PDM
Tue Feb 15, 2011 5:33 am
by Motorsport Eng.
Great!!!
this sounds good for the new ecu.
when do you expect a brelease for M84?
Is there a release for PDM as well to obtain the mentioned channel working?
B.Regards
Re: M84 and PDM
Fri Feb 18, 2011 1:45 pm
by MarkMc
The release will hopefully be soon, we just have to make sure all the changes are good.
There is no need for a special version of PDM manager becasue you can configure the CAN inputs to the PDM as you like.
Attached is a configuration for the PDM with the M84 CAN channel.
Re: M84 and PDM
Thu Nov 08, 2012 11:09 am
by mstech
Can a M84 and PDM15 be configured so that the ECU can use the CANBus to control the fuel pump, thermo fan and other functions not included in the list in the above post, or is it only those CANBus messages available?
Re: M84 and PDM
Fri Nov 09, 2012 9:24 am
by MattW
mstech wrote:Can a M84 and PDM15 be configured so that the ECU can use the CANBus to control the fuel pump, thermo fan and other functions not included in the list in the above post, or is it only those CANBus messages available?
These messages should be enough for the PDM to control these devices.
e.g:
Fuel pump - Prime when first powered up and on when over 50rpm
Thermo Fan - On when Engine Temp over 80 and Groud Speed under 60
etc.
Re: M84 and PDM
Tue Oct 22, 2013 10:15 pm
by Martin
Is there any document describing how to set up M84 to PDM Comms?
