Electronic throttle control
Re: Electronic throttle control
Postby gtihk on Tue Feb 26, 2019 1:49 pm
I think we have been through this before. Please look back on previous posts.
I really don't think you can run wasted spark on a 3 cylinder engine.
I think you need to add a sync sensor as suggested to make it work.
A DBW throttle will not help in any way to enable you to start the engine.
gtihk
Postby xiaoyaowangdaren on Sun Mar 03, 2019 7:45 pm
Hello, my friend, I am sorry that I did not reply your message. I was busy starting triumph 675, but I still could not start successfully.
In the information of M84, the 1-8 cylinder engine can be started, so can the 3-cylinder engine.
But I do not understand, why can only start with synchronous signal, such M84 inside the Settings can not start the 3-cylinder engine, even the most basic can not be achieved, then it will lose its role.
I don't know what my mistake was.
xiaoyaowangdaren
Postby gtihk on Tue Mar 05, 2019 1:39 pm
The M84 can run a three cylinder engine only with the right sensors.
As far as I can see, since you do not have one throttle per cylinder, you cannot use MAP sensor for sync.
The only option I can see is to add a cam sensor.
gtihk
Postby xiaoyaowangdaren on Tue Mar 05, 2019 2:12 pm
Hello, friend, I'll consider your advice. Thank you
xiaoyaowangdaren
Postby Vlad on Sun Mar 10, 2019 7:19 pm
I am currently running on my SR20VET a M84 with a stand alone DBW controler i've made, they only share tps and idle pwm signals, i've been running it for almoast a year now and never had any trouble with it :D
Vlad Pescaru
Vlad
Return to M84 ECUs
