Suzuki GSX 1100 Best trigger wheel to use
Re: Suzuki GSX 1100 Best trigger wheel to use
Postby SprinterTRD on Mon May 18, 2020 1:06 pm
harky wrote:pm me , i will email you photos
having no luck posting any
I think you can use a crank only sensor , but that will limit you to non sequential injection
Yes, but you would need to run a missing or additional tooth crank sensor. But you will need to run waste spark on your coils
Press F1 in the software for more help.
Postby Screwriverracing on Tue May 19, 2020 5:11 am
Thanks sprintertrd,
That was going to be my next question, I was going to use a 12 tooth wheel of a Kawasaki zzr1400 as this will fit quite easily without to much trouble, then I was wondering how the ecu would no when the engine was a tdc with out the cam sensor.
Would a 12 - 1 wheel work?
This way I could get it up and running with just swapping the wiring from my existing ecu for now.
Cheers SRR
Screwriverracing
Postby SprinterTRD on Tue May 19, 2020 9:42 am
I think you will have issues with 12-1 mainly during cranking. Check the help file for the minimum teeth required.
Additional tooth may be a better option
Postby Screwriverracing on Fri May 22, 2020 9:23 am
And next,
Does anyone know what injectors these are
Number on them is D3183BA.
Cheers SRR
Screwriverracing
Postby Screwriverracing on Thu Aug 13, 2020 4:55 am
Have found a bike running the zzr 12 -1 wheel, but also has a cam sensor on M84.
Would it be possible to run it without a cam sensor non sequential and wasted spark?
Cheers SRR.
Screwriverracing
Postby Stephen Dean on Mon Aug 17, 2020 12:27 pm
I do not have any information for that injector part number.
Postby Screwriverracing on Fri Sep 25, 2020 7:01 am
Right,
To awkward to fit a cam sensor, so how about a Drive of the end of the crank and geared the same as the cams with a sensor on that?
Will it work?
Cheers SRR
Screwriverracing
Postby harky on Fri Sep 25, 2020 3:06 pm
there is no reason why that won’t work , you can get CRIP from that
the photos of the cam sensor i did on the Kawaka GPZ. don’t do the fit justice ( mainly because the photo was upside down—- (. always have your i phone or ipad with the home button on the right or bottom )
the cam cover is Magnesium , which required special tig welding.
simple is best —- , keep at it.
if it helps. give me your email , i can send much better photos —— much easier than posting here
cheers
harky
harky
Postby Screwriverracing on Sat Oct 03, 2020 1:55 am
Hi Harky,
You have a pm with my email on.
Cheers SRR
Screwriverracing
Return to M84 ECUs
