About the setup of triumph 675
Re: About the setup of triumph 675
Postby FSC-China on Sun Feb 17, 2019 5:41 pm
Thank you very much for the blessing from a distant friend!
Yes, I am still groping for mode 8 without the camshaft sensor, which is not going very fast.
Our rules allow camshaft sensors, but I don't have any experience with how to install camshaft sensors, so do you have any information or experience to pass on?
Thank you very much!
FSC-China
Postby SprinterTRD on Tue Mar 05, 2019 4:37 pm
It looks like your capture has 22 teeth do you have this set up in the number of teeth for REF?
Are you using falling edge for the REF sensor?
Pull the spark plugs out and do another capture.
While the spark plugs are out see if it syncs up.
Postby FSC-China on Wed Mar 06, 2019 12:19 am
Thank you very much for your help.
Yes, I have set it, but now I am using the rising edge trigger, using the two-stroke mode 8, but the problem I met makes me unable to understand.
(1) in the first case, when I pulled the spark plug from the cylinder and started the ignition without the cylinder pressure, I saw that the ignition and fuel injection were normal.
(2) the second situation is beyond my understanding. When I put the spark plug back into the cylinder and started it with cylinder pressure, my ignition and fuel injection were normal when the throttle was fully closed, but the ignition and fuel injection were disconnected when I opened the throttle.
I have ruled out the throttle position sensor. I think there will be no ignition when there is air coming into the cylinder from the inlet, because it is normal to fire and spray when I plug the throttle valves of cylinders 1 and 2 or 1 and 3.
I think there's something wrong with my setup,
If you can help me, can you give me your email address? I will show you my current Settings.
Attached is a crankshaft signal diagram I collected.
FSC-China
Postby FSC-China on Wed Mar 06, 2019 12:26 am
This is the collected signal graph
Triumphant 675 20190226.rsc2
(64.45 KiB) Downloaded 1073 times
FSC-China
Postby SprinterTRD on Wed Mar 06, 2019 8:43 am
Looks like you changed the wiring for the sensor from the original capture.
Your problem is the cranking consistency, for some reason the crank is decelerating/accelerating even with the spark plugs out.
By opening the throttle you are putting more load ( by introducing more air) on the starting system making the REF signal even worse. In this case the ECU cannot detect the missing teeth which is why the injection and ignition disappear when you open the throttle.
Fix the starting system.
Postby FSC-China on Thu Mar 07, 2019 8:46 pm
So on the boot side I can change the Settings or what's on the hardware
FSC-China
Return to M84 ECUs
