Water temp failure
Re: Water temp failure
Postby SprinterTRD on Thu Apr 16, 2015 9:45 am
B15 & B16 should go to the sensor grounds only.
The B 15 & B16 pins should not be attached to chassis ground in the loom, The only path to ground for B15 & 16 is internally in the ECU to A10 & A11. This helps prevent electrical noise on the sensors.
Postby Troclo on Fri Apr 17, 2015 6:30 am
Thanks for clearing that up, i will test the ecu tomorrow. Cheers!
Troclo
Return to M84 ECUs
