Can't setup GPS!!
Can't setup GPS!!
Postby dermizu on Sun Oct 16, 2011 1:22 pm
M84 ECU Manager Ver 1.10K2 can't adjust RS232
There no RS232 telemetry Setup at
Adjust>General Setup>Communications
Tell me How to Set Up or Send Program Patch
dermizu
Re: Can't setup GPS!!
Postby OmarK on Tue Oct 18, 2011 1:24 pm
The RS232 RX on an M84 is fixed to a Baud rate of 19200 and cannot be changed as this is hardcoded into the firmware. Are you using a GPS with a different baud rate?
OmarK
Postby dermizu on Fri Oct 21, 2011 4:33 pm
My tuner connected
GPS TX PIN to ECU TX PIN
So, it's reconnect
GPS TX PIN to ECU RX PIN
It's working!!
Thanks.
dermizu
Return to M84 ECUs
