Feature Request...
Feature Request...
Postby gts_215i on Thu Aug 04, 2011 12:45 am
Request to unlock the ignition outputs - especially when using an ignition expander or CDI
gts_215i
Re: Feature Request...
Postby MarkMc on Wed Aug 10, 2011 6:20 pm
Sorry but that is an M800 thing only, even the M400 and M600 cannot do it.
Postby Prigor on Sun Aug 21, 2011 7:46 pm
Why does M84 have RS232 enabled only for GPS? It would be great if you would enable telemetry via RS232 since it is the only ECU that doesn't have this enabled.
Prigor
Postby MarkMc on Tue Sep 06, 2011 5:53 pm
The M84 is a replacement for the M4 and M48 and is not an Hundred series ECU so the featurs are different. We have not found that htere is a huge need for RS232 output from the ECUs these days as nearly all external devices are CAN.
Although there has been a request logged for this so you may win this one. :)
Postby Prigor on Sun Oct 02, 2011 7:41 am
When is a new version of firmware for the M84 going to come out? Are there any plans for this in the near future? There are some bugs with the current version (like mismatching files on connecting with the ECU even with no changes made whatsoever)...
Prigor
Return to M84 ECUs
