Our engine can run smoothly with diffdrent TPs.
But after the TP gets to 0%,it always stop.
Temperature >100 ℃
lambda<0.85
Now I have a problem with M84 ECU.
When I change the throttle position from 80% to 0(idle) at about 110 ℃,the engine always can not idle.
It always runs at idle speed(1300RPM) for a few seconds,then the speed down to 1000 and 700 and lower,then stops.
And the lamdad that time is 0.8 and sometime even is 0.7.
But when I start the engine,it can idle normally.
I have changed the engine temperature cmop and reduced the fuel at idle.
So I think I should set up the fuel decel.
But I do not know how to set it up.
Please help me.
And do you think what results in this?
Thank you!
