Knock control
Knock control
Postby Dubridze on Tue Nov 16, 2010 10:50 pm
Hello.
I want to migrate from F-Con Vpro ecu to Motec M84 and i have some questions
Is it possible to activate knock control function with SKM?
Could you make MAP oriented startup calibration file for Evo7 JDM?
Dubridze
Re: Knock control
Postby DuaneM on Thu Nov 18, 2010 10:34 am
The M84 does not have knock control as an option. The M400,M600, and M800 would be the ECU models you'd need for this capability.
DuaneM
Re: Knock control
Postby Dubridze on Fri Nov 19, 2010 5:30 pm
Can i use external knock control system and use analog output from this system for user compensation map?
Dubridze
Re: Knock control
Postby JamieA on Mon Nov 29, 2010 3:58 pm
The M84 has been designed to be a lower cost ECU, and as such, some of the more advanced features such as knock measurement and control are not available.
Accurate Knock measurement is far more difficult to do than most people understand, and if it is done inaccurately, it can do more harm than good (by reducing engine power unnecessarily, or by allowing knock that you assume is being stopped)
If you are going to spend the time and money required to do knock measurement accurately, then you would be more the type of customer who we see would use an M400, 600 or 800 with its more advanced features.
regards
Jamie
JamieA
Re: Knock control
Postby miguel st205 on Thu Dec 16, 2010 2:32 am
Dubridze wrote:Can i use external knock control system and use analog output from this system for user compensation map?
I want to know this too... can we use something like the Phormula KS-4 and use one of the analog 0-5v inputs of the M84??.. Does this going to be "something" accurate??.
It's definitive or "maybe" in the future we may expect an upgrade with the SKM or some??..
Thanks in advance...
P.S.: people, do you know some other brand of Knock Detection that has analog 0-5v output??..
miguel st205
Return to M84 ECUs
