Alfa 75 GTA 3.2 not firing
Postby Abruzzo116 on Fri Sep 27, 2024 12:50 pm
Hi Guys,
I have an alfa 75 GTA 3.2 V6 that will not start. I have injector pulse and spark to coils.
I also have crank and cam sync and fuel pressure.
Engine is freshly built.
Trigger disc is 60-2.
I have attached file with mapping if someone can take a look at it and alter any changes required.
alfa 75 v6 24v map copy.m84-12
(72 KiB) Downloaded 2 times
Abruzzo116
Re: Alfa 75 GTA 3.2 not firing
Postby David Ferguson on Sat Sep 28, 2024 2:42 am
Assuming this was starting and running prior to the rebuild -- Have you tried changing your CrIP by 360 degrees?
Return to M84 ECUs
