About the initial engine start
Postby FSC-China on Sat May 25, 2019 7:26 pm
hello!
Has anyone ever had a problem with an engine that when the throttle is completely off, the engine starts up very well, and the engine starts up with no acceleration or deceleration?
But when you open the throttle a little bit (1%, 2%, 3%, 4%, 5%...), it will fail to start without a direct ignition and fuel injection signal.
I don't know if this is my setup problem, because when I unplug the throttle position sensor it is the same phenomenon as above.
Thank you very much!
FSC-China
Re: About the initial engine start
Postby FSC-China on Sat May 25, 2019 10:50 pm
After closing the throttle and starting successfully, there is no problem with acceleration and deceleration
FSC-China
Postby Vlad on Sun Jun 16, 2019 11:56 pm
Cranking fueling and firs injection might be set to low, making the mixture 'lean' when you add in extra air through the throttle plate
Vlad Pescaru
Vlad
Return to M84 ECUs
Users browsing this forum: No registered users and 37 guests
