So I'm not a techy but I do want to try and understand what I need to buy to convert my current standard engine management system to the M84 and loom that I've acquired.
I have a kit car running a stock AU2 XR8 windsor including the Ford ECU but with the security switched off, care of a Ford techy, standard coil packs and MAF intake, all as sourced from a donor Ford AU many years ago.
I'd like to slightly cam the motor but have learnt the standard Ford ECU can't handle this, hence the acquisition of the M84 to overcome this issue.
Another conversation seems to suggest I need some form of driver to run my coil packs with the M84, else I need to re-discover a distributor set up, is this correct?
I'd prefer not to go the distributer route so need to understand what it is I need to buy to run the coils.
I am also aware that there might be various sensors required.
What might these be and what are they measuring?
I am hoping someone can explain in layman's terms what I need to be aiming for to achieve this conversion.
Cheers
