Volkswagen 16V ABF sync/ref/crip
Postby timborallyman on Mon May 21, 2018 1:47 pm
PLEASE HELP
Hi I have a ABF engine with 60-2 teeth.
I have attached a picture from the factory technician manual (in german)
I need to input the sync/ref value.
I am not sure of the following:
sensor type's.
ref/sync mode
crt
crip
Capture from self study program.PNG (88.32 KiB) Viewed 11487 times
timborallyman
Re: Volkswagen 16V ABF sync/ref/crip
Postby Stephen Dean on Mon May 21, 2018 6:20 pm
Is the M84 wired to the engine? If so, please do a Ref Sync Capture and attach it to your reply. This will assist in determining the Ref Sync mode needed.
For the sensors, typically a Hall effect sensor will have three wires, and a Magnetic sensor will have two. This can only be determined by either looking at the sensors, or from the wiring diagram. The attached image has a signal shape that looks like a Hall effect sensor, but I would not trust this.
CRT will be 60.
Crip will need to be determined on the engine.
Postby timborallyman on Mon May 21, 2018 11:20 pm
Hi. Thank you for your time. I have got the car to start briefly but will not continue to run around the
sync mode 7
ref teeth 60
tooth ratio 58
ref sensor type 1.
ref edge pol 0
ref trig volt 0
sync sensor type 1
sync edge pol 0
tync trig volt 0
I have since found there are four cut outs in the sync sensor (distributor).
I am thinking I am way out with my crip as I cant get the engine to run for more than 5-6 seconds.
Not enough sleep....
Thank you again for your advice.
Working capture.rsc2
(64.45 KiB) Downloaded 1177 times
timborallyman
Postby Stephen Dean on Tue May 22, 2018 12:31 pm
There is only one tooth showing in the Ref Sync Capture, and it is not moving around, so it is a stable sync.
It sounds like your CRiP is out, but may not be by much. Use a timing light to get the requested ignition timing to line up with the actual timing.
Postby timborallyman on Tue May 22, 2018 3:35 pm
Hi SDean
I have the crip spot on in the ignition timing check screen. it runs just then dies.
Starter motor now getting tired...
Time to get a professional on the job.... Any other ideas?
Regards Tim
timborallyman
Postby Stephen Dean on Wed May 23, 2018 11:30 am
If the timing is correct and there are no errors coming up, the next area that I would look at is fuelling. Try adding a 50% trim into the fuelling and see if the engine behaves better doing this.
What may be happening is that the cranking compensations are adding enough fuel to get the engine started, but when they run out, and the fuel film that had formed is used up, then the main fuel map may not be delivering enough fuel to maintain engine operation.
Return to M84 ECUs
