Change pressure units in M84
Postby jwm on Thu Apr 21, 2016 12:30 pm
Hi
How do i change the units for oil pressure and fuel pressure etc being sent to dash by M84
Have a conversion issue with my C125
jwm
Re: Change pressure units in M84
Postby adrian on Thu Apr 21, 2016 2:19 pm
What units are you using in the ECU? The dash assumes everything is sent in SI units so if you have your pressure channels in PSI then you will need to either change it back to kPa in the ECU or convert it in the dash.
Postby jwm on Thu Apr 21, 2016 11:28 pm
Units in Ecu are in PSI. Was wanting to know how to change them.
Cheers
jwm
Postby Stephen Dean on Fri Apr 22, 2016 9:52 am
In the Input Setup page, you select the units used for the Input by selecting the appropriate calibration. This is shown in the brackets in the name as to which unit is used.
M84 inputs.JPG (93.68 KiB) Viewed 13153 times
Return to M84 ECUs
