Fuel cut on tps value
Postby wetterhus on Sun Feb 01, 2015 9:21 am
Hi
Running a M84 on 4 cyl with 4 cop, 60-2 and sync on camshaft
Everything running just fine until I exceeds 20% on the tps signal.
If I go over 20% tps the F APW (ms) goes to zero
It happens all over the rpm range
Any suggestions ?
wetterhus
Re: Fuel cut on tps value
Postby AdamW on Sun Feb 01, 2015 4:16 pm
Please post your cal and a log.
Motorsport Electronics Ltd.
AdamW
Postby wetterhus on Sun Feb 01, 2015 10:00 pm
Tried to upload the map but get this message : The extension m84-11 is not allowed.
wetterhus
Postby AdamW on Mon Feb 02, 2015 7:44 am
Try putting your cal inside a .zip file, im pretty sure the forum will attach that ok. If not you could share it using a sharing site or google drive, onedrive etc.
AdamW
Return to M84 ECUs
