M84 and Motec PLM over CAN
Postby kurtd on Fri Apr 19, 2013 4:04 am
Can someone tell me how the Sensor Setup->Input Setup entry for Lambda 1 should be configured if I have the Motec m84 connected to my Motec PLM over CAN? What calibration setting should be used, and do I use it as "Predefined" vs. 1-to-1/Custom? I have used a CAN analyzer to confirm that that CAN messages are going over the bus from the PLM (configured as device 0x460). the ECU manager is not showing any readings for La1 though.
Thanks!
Kurt
kurtd
Return to M84 ECUs
