Mark & Jamie no doubt you will have heard me discuss this before, but could we PLEASE have a few more logging channels available (currently set to 16). I understand the business model of M84, replacing M4/48 et al, but there is a significant gap between M84 and Mx00 series...16 vs 64 channels.
At the moment, a large proportion of the max of 16 are taken by mandatory (ie: can't be changed) diag channels, so your effective chnnels avaialabel is much lower at around 8 or 10...inadequate for the excellent capabilities of this well-priced and otherwise well featured ecu.
For example, if you are logging a single bank turbo engine, and running CL lambda and CL boost, you would want as a minimum:
rpm
TP
Lambda Aim
Lambda La1
MAP
Boost Aim
Boost ERR
Aux duty % for WG channel
Boost Comp
Ign ADv
EGT.......................11 channels minimum, and this is only one lambda!
It does not include coolant temps, inj duty, fuel/ign at/et comps...etc....simple stuff even for a club racer than are required for accurate logging at the track/dyno to ensure safe operation....
If we can't have any more than 16 (even only 24-30 would do), can you make it so you can turn the diag channels off to temporarily free up some more? Even the ability to pay a nominal fee to unlock 20 more or something, although not desirable, would be better than the current limiting situation!
You did a good job with putting the RS232 messages back in, please add this easy one to the next SW upgrade!
Last ditch alternative: At the moment, i use a Mx00 as an "tuning ECU" with the options enbables, and lots of logging channels whilst on the dyno, but covert the cal from Mx00 to M84 software manually to put into customers ECU to test before letting it out the door. I have made an Mx00 confi that matches the non-changeable table configs of the M84.
However, could you guys come up with a file convert (or table convert) utility to take a Mx00 file config and put it into M84 format?? At the moment you have to do it tabel by table, export csv, import csv, etc. But you also have to manually enter the single variable paramters one by one---very time consuming!!
Much easier with convert utility from Mx00 to M84, or just allow another 10-14 logging params in the M84!!
Over and out for now:
T.
