frankenferrari V12
Re: frankenferrari V12
Postby greenamex2 on Fri Apr 10, 2015 2:36 am
Scott@FP wrote:A standard potentiometer such as a TPS or linear or rotary position sensor, or a multiplexed position switch works just fine on a 5v biased AT circuit. Instead of using 3 wires you use two.
Thanks, but unfortunately I am using IC controlled sensors that emulate pots by giving a proportional voltage output....so I need something without a pullup confusing things.
greenamex2
Postby Scott@FP on Fri Apr 10, 2015 3:54 am
I have a multifunction process calibrator, which simulates a TC input by mV or temp and has all the common NIST TC type mV tables in memory, a current to 24mA, or a voltage to 20v, and can step by 1 mV. Just hooked it up to an M800 and put a voltage output onto an AT input.
It read correctly to 1mV.
It really depends upon the nature of the sensors output whether or not it will work on an AT input, maybe there will be an offset applied, maybe not, but if you are short inputs its worth a try, and offsets can be compensated for in the sensor calibration. Its worth experimenting with.
Multifunction process calibrator, I don't know how I lived without it, very handy tool, and these days they are pretty cheap.
Postby greenamex2 on Fri Apr 10, 2015 4:14 am
Interesting.
I'll give it a go at the weekend.
greenamex2
Postby mk e on Sat Apr 11, 2015 1:14 am
So now that I expanded the AN options a little JamieA on the GPR thread convinced me to just buy something like this:
TRK-USB-MPC5602P
http://www.digikey.com/product-detail/e ... mt=b&pdv=c
Its $25 and has CAN, serial, and an ADC with 15 inputs....so it can read the innovate WBO2 control serial signal or the analog out and all my NB sensor then emulate an LTC to pass it to the M150. I just need to find time to make this happen so I'll stick with the analog work a round for the moment. Frustrating I need to do this, but not the end of the world either I suppose.
mk e
Postby greenamex2 on Sat Apr 11, 2015 1:31 am
You'd probably need the full version, but still only $75 -
http://www.digikey.co.uk/product-detail ... ND/2674238
greenamex2
Postby mk e on Sat Apr 11, 2015 4:05 am
denis bassom wrote:You'd probably need the full version, but still only $75 -
I have a couple of these:
http://www.digikey.co.uk/product-search ... ds=mpc5634
same thing as you found but more stuff in the processor and $99US .....I'm using it for an opensource ECU I play with:
http://open5xxxecu.org/
Basically what's running the M1xx ecus (MPC5566), just fewer pins.
I like the 5602 because its cheaper and smaller but will run the same code so everything I already have for o5e would work, I just need to add a CAN output, which was on the to-do list anyway. I could make a little dongle that sells for like...$100 and reads innovate serial data and has 15 AN inputs so you could read I think 32 innovate devices serially PLUS an additional 15 analog signals and send it all out to the ECU on CAN.......for $100.
Maybe do another version with 8 or 12 EGT inputs on it....for $100
mk e
Postby mk e on Sun Apr 26, 2015 3:14 am
Still mad the M150 has 2 lambda pins it can't use for lambda.......a buddy said he's got some time to help out so I just got a couple of the TRK-UBS-MPC5602P boards to make a couple prototype AN to CAN units. They'll have calibration lookup tables on all the AN so it can read any NB sensor or WB controller and replace 8-12 LTC units (depending what connector we find) or send any other AN signal in for the pins challenged M130. If it works I'll have some run off and through them on ebay for anyone else who needs it....it shouldn't be more than $100. Problem solved.
2015-04-25 003.JPG (272.06 KiB) Viewed 30293 times
mk e
Postby AdamW on Fri May 01, 2015 7:25 pm
Just in case you guys weren't aware of this one: http://etesta.com/etesta-products/ana2.html
I have no ties to the product and have never used one, just stumbled across it a while ago. @$300 for 12 extra AV's it might be easier than doing it yourself...
Seems like all his electronics are aimed towards the M1's.
Motorsport Electronics Ltd.
AdamW
Postby greenamex2 on Fri May 01, 2015 9:25 pm
AdamW wrote:Just in case you guys weren't aware of this one: http://etesta.com/etesta-products/ana2.html
Neat little toy, and the article on wifi is pretty handy.
greenamex2
Postby greenamex2 on Mon May 04, 2015 1:56 am
Scott@FP wrote:I have a multifunction process calibrator, which simulates a TC input by mV or temp and has all the common NIST TC type mV tables in memory, a current to 24mA, or a voltage to 20v, and can step by 1 mV. Just hooked it up to an M800 and put a voltage output onto an AT input.
For info, the pressure output of the sensor reads OK on an AT input (slight offset, just need to change the table)....the temperature output on the sensor doesn't read at all on an AT input. A bit ironic that the temperature sensor doesn't work on an AT input! Still, freed up a knock sensor input so good enough.
A single knock sensor on a V6 probably isn't ideal but still better than NONE.
Thanks for the tip.
greenamex2
PreviousNext
Return to Customer Projects
