Help with choppy video in I2 Pro
Sun Nov 27, 2016 3:23 pm
by adelaide
I have recently reformatted my drive and had to reinstall I2 Pro. Now when I play the video with overlayed data in I2 Pro, the video is choppy like it is missing frames or something. I have tried everything including contacting Motec directly and still having the same problem. Anyone out know how to fix this annoying problem? I have a Microsoft based PC running windows 10. Thank you.
Re: Help with choppy video in I2 Pro
Sun Nov 27, 2016 5:04 pm
Do you realize that the video will generally run much smoother if you have the video component selected? Just point your cursor at the video and click.
Did you install the MainConcept video codec when you re-installed I2 Pro?
Mon Nov 28, 2016 9:39 am
Hi Adelaide,
If the video window in i2 is not highlighted during playback, the data window that has the highlight becomes the timing master, and plays at the correct rate, and all other windows perform a synchronised frame capture from the current data cursor position. This is the only way that synchronisation between the data and video files can be correctly maintained.
Also, when and how did you try contacting support? I have no record of this issue being raised and if you tried to send an email in through the support @ motec.com.au email address, it wasn't received. if you can supply some details I would like to look into this.
Wed Dec 14, 2016 2:46 pm
by adelaide
Thank you for your assistance. I called Motec East in the USA. I cannot remember who I spoke to. She was helpful but my system is still not operating correctly. I did as she stated and converted my video files to WMV and it still did not solve the problem. No idea what to do now.
Wed Dec 14, 2016 4:56 pm
by adrian
How big are the files you are having issues with? Would you be able to upload one (wetransfer or dropbox etc) for me to test?
If you have the video window highlighted in i2 it should play smoothly. If you go to the Windows Task Manager what sort of CPU usage do you get when i2 is playing a video?
