Injector size for 302 Windsor
Posted: Wed Dec 23, 2009 10:28 pm
I'm putting Quad IDA throttle bodies on a 302 Windsor (aiming for ~ 400-450 hp and good looks ) and I'm wanting to run the injectors down the middle. But with the std type injectors the fuel rails hit and wont work (I assume 30lb/hr ones are in the ball park). There are Seimens short ones that will fit but are rated at 60lbs.
Are these too big to control at idle ??
Are there any other injectors that are around the same length ??
If 60lbs is too big, how big can I go before having trouble with starting and idle control ??
Will be controlled by a M800.
Thanks in advance
Clayton
Thanks in advance
Clayton
