4g92 mivec
PostPosted: Mon Dec 21, 2009 6:14 pm
by hornet75
hello anyone,just wondering if anyone out there has had experience with the 1.6 DOHC 4g92 mivec engine we have a m48 ready but tips would be appreciated.will be tuning for race application
Re: 4g92 mivec
PostPosted: Mon Dec 21, 2009 11:20 pm
by Martin
You will need a Mx00 ECU to do continuous variable valve timing. The M48 will not do continuous variable cam timing, only 2 position cam timing.
Re: 4g92 mivec
PostPosted: Tue Dec 22, 2009 6:55 am
by hornet75
4g92 mivec is not continuously variable this is only mivec 1 which only has high /low cams,the mivec system only requires switching on at rpm
Re: 4g92 mivec
PostPosted: Wed Dec 23, 2009 7:45 am
by Martin
My apologies, I thought that Mivec referred to their continuous variable valve timing system.
M48 Will do 2 position control.
Is it wasted spark like the 63's?
Trigger pattern?
Re: 4g92 mivec
PostPosted: Wed Feb 10, 2010 8:22 pm
by hornet75
sorry martin its been a while, yes mate it it the same as 63 can you help ?
Re: 4g92 mivec
PostPosted: Thu Feb 11, 2010 5:36 am
by Martin
What would you need? I havent got a map...but I could send you a 4G63 map if you wanted? Ill be in Mx00 but you can read all the settings there that you would like to know..
Would it be ok?
Re: 4g92 mivec
PostPosted: Sun Feb 14, 2010 10:56 am
by hornet75
yeah mate i suppose its worth a try thanks
Re: 4g92 mivec
PostPosted: Mon Feb 15, 2010 2:55 am
by Martin
pm me you email address
Re: 4g92 mivec
PostPosted: Tue Feb 16, 2010 6:35 pm
by hornet75
sorry mate i would reply but pm not working or im doing it wrong
Re: 4g92 mivec
PostPosted: Wed Feb 17, 2010 2:34 am
by Martin
If you give me your email address here Ill mail you what I have.
