Idle control PID
Posted: Sat Nov 28, 2009 5:40 am
Hi All,
im trying to find out what are the best way to make the idle control best.
My daily driver is a 5 cylinder Audi with M600.It has a 2 wire BOSCH PWM idle valve.
Getting proper idle is not a problem,with "constant" electrical load,i just need to set the Normal Position to a good value.
But when this load changes to anothe constant load(wiper,headlights,heater,colant fan on),the rpm drops,and the PID cannot keep up with the increased air/RPM need.From the logs its clear that the ECU tries to increase the duty,but its slow,and not sufficient.I just want to refine it.
With more P I or D it just begins to be unstable.
Any help appriciated.
Thank you,
Peter
Thank you,
Peter
