Fuel swirl pots, twin 044 pumps and fuel heating
I have a higher than stock flow capacity, but stock style and mounted high pressure in tank fuel pump (In a Skyline R33 stock fuel tank) feeding a large swirl pot at low pressure via a filter and a short -6 line. The pot feeds twin Bosch 044 fuel pumps via -10 hoses. The pumps are T'd together via 2 filters, and feed the fuel rail through a -8 line. The return from the FPR is into the swirl pot, high up via -6. The return from the pot itself is into the main tank via -6 I have read about recirculating fuel absorbing heat from the pumps and the fuel rail / engine to the point vaporisation problems occur. I was toying with having the two 044 pumps on separate relays and just using one unless on track. Engine should make a genuine 700 BHP on decent fuel. Injectors a re Siemen 800 cc. I was considering setting base fuel pressure at 3.5 bar. None of this is running at the moment. Should I be addressing anything at this stage? The car is 90% track day car, but I may MOT it and drive it occasionally on the road to and from local circuits. ECU is M800. Is it easy to make the M800 control the second HP pump? On what criteria, RPM or MAP sensor output, or something else? Thanks.
