Injector Battery Comp
Tue Oct 20, 2009 9:25 pm
by mhd
Hi every body
Does any one know how to be sure about Injector Battery Comp setup
coz I think my setup not corect
Thank's
M.Olabi
Re: Injector Battery Comp
Mon Nov 30, 2009 3:43 am
by forcefed1981
Hi
Run car on idle with multimeter attached to battery and check voltage should be above 13 volts and also check fuel mixture reading.Then disconnect alternator from battery run car on idle again if you can do this with your car,check voltage is lower then before then check fuel mixture stays the same.If not adjust battery comp till fuel mixture is close as you can get it.
Thu Dec 03, 2009 5:43 pm
by mhd
Thank's very much for your help
