Why Motec ECU have not TP and SPEED Compensation .
Postby Fueltank-Tai on Thu Oct 15, 2009 4:50 pm
Dear Motec:
I have some questions about (Why Motec ECU have not TP and SPEED Compensation .) I knew Some Brand ECUs which are with TP and SPEED Compensation . I donot understand Why Motec ECU have not TP and SPEED Compensation . Could you explain to me . Thank you so much.
Fueltank-Tai
Re: Why Motec ECU have not TP and SPEED Compensation .
Postby IJ. on Thu Oct 15, 2009 7:57 pm
Not really understanding your question as you can assign anything to the X/Y axis for most of the compensations.
What are you trying to do?
IJ.
Postby Fueltank-Tai on Thu Oct 15, 2009 8:14 pm
Dear IJ:
I found the X/Y setup functions. Thank you so much.
Fueltank-Tai
Postby IJ. on Thu Oct 15, 2009 8:31 pm
Very welcome! :)
The version 3 software is brilliant in this respect you can tailor it to suit whatever you want it to do.
IJ.
Postby Fueltank-Tai on Thu Oct 15, 2009 10:51 pm
Dear IJ:
Do you know M4 Pro is with TP and Speed Compensation function? I cannot find this function in M4 . Thank you so much.
Fueltank-Tai
Postby IJ. on Fri Oct 16, 2009 7:48 am
Sorry FTT I only "speak" M800/V3.0 ;)
I don't have any experience with earlier ECU's and Softwares as I was a late MoTeC adopter and spent far too many years struggling with lesser products.
I'm sure someone that knows will be along shortly (The other advantage to MoTeC is people that reply actually "Know" and aren't guessing)
IJ.
Postby RossB on Fri Oct 16, 2009 8:33 am
The M4 is a bit limited when it comes to axis setup on tables compared to the M800. Can you tell me exactly what it is you want to do as a compensation? Then I may be able to suggest a solution for you that is within the capabilities of the M4 Pro.
Return to Tuning discussions
