Injector Battery Comp Power Enterprise
PostPosted: Wed Oct 14, 2009 9:40 pm
by alexflamingo
I need the value for Comp Injectors Injector Battery Powe Enterprise 18-ATL3-800 which are 800cc, I would also injectors Sard 63500th 700cc
Many thanks
Re: Injector Battery Comp Power Enterprise
PostPosted: Thu Oct 15, 2009 8:42 am
by RossB
Hello Alex,
The Sard 63500 settings are:
Current 3
Peak & Hold ratio 4
Battery compensation.
Code: Select all
   Fuel Pressure (bar)
Volts      3   4   5
10      970   1121   1210
11      875   1004   1091
12      878   906   955
13      826   846   885
14      773   785   817
15      745   731   755
PostPosted: Thu Oct 15, 2009 4:15 pm
by alexflamingo
Thanks, the data for the Power Enterprise Injector Where can I get?
PostPosted: Thu Oct 15, 2009 9:22 pm
by alexflamingo
After some research I discovered that the Power Enterprise are built by Denso, if you can find these specifications make me pleasure. Thanks
PostPosted: Fri Oct 16, 2009 8:28 am
by RossB
If you have a Denso part number I can look and see if we have any data.
PostPosted: Sat Oct 17, 2009 7:24 pm
by alexflamingo
Hello Ross, the symbol of the injectors and dense 1001-87095 or 1001-ST095
PostPosted: Mon Oct 19, 2009 8:20 am
by RossB
Denso 1001-87095 is a good number but we haven't got any battery comp data for this injector, sorry.
PostPosted: Mon Oct 19, 2009 6:14 pm
by alexflamingo
thanks for the answers, creeds to succeed in finding me these data?
Does a have conceive of which gives I can use for these injectors?
I have 3 autos that these injectors climb on and I have climbed on M800, if you succeed to make me have some datum I am thankful of it
Regards
