What can MOTEC do......LS based engine / 4L80E transmission
Postby WS6RollRacer on Fri Apr 12, 2024 1:59 am
new here.
I have a 1998 WS6 Trans Am that is on the road to break in its new engine. After break-in the turbo kit goes on. Goal is 1500 RWHP.
Does Motec have a Traction Control mode that will work with my set up? I'll be using a DBW throttle body if that matters.
This is a big thing for roll racing with my power level. I saw a youtube video of a guy roll racing several diffferent cars and winning every race. The cars he was racing all had more power, in one case 500 HP more but they were spinning their wheels.
The guy with Motec kept saying these wins are all about the Motec helping put the power down.
Also, I was going to use the Holley Terminator X for engine/trans management. Can I just use Motec for all my management needs.
thanks,.
WS6RollRacer
Re: What can MOTEC do......LS based engine / 4L80E transmiss
Postby Stephen Dean on Fri Apr 12, 2024 10:15 am
We do not do a standalone Traction Control module, it is integrated into our ECU's. We can run the LS engine and have support for the 4lx0E gearbox.
Where are you located?
Postby WS6RollRacer on Fri Apr 12, 2024 1:46 pm
Stephen Dean wrote:Hi,
I’m located in Ft. Lauderdale, Florida (USA).
So how does the Motec ECU improve traction?
WS6RollRacer
Postby stevieturbo on Mon Apr 15, 2024 7:24 am
You need to have a long chat with your chosen tuner before you go much further.
They will be as, or more important than whatever ecu platform you choose.
Postby Stephen Dean on Mon Apr 15, 2024 10:22 am
There is an internal Traction Control functionality in the M1 Firmware, depending on the Firmware version and how it has been configured, it may reduce engine power by closing the throttle, applying ignition retard or ignition cut or a combination of the three.
Postby WS6RollRacer on Tue Apr 16, 2024 5:08 am
Ok…..thanks you guys for the info.
WS6RollRacer
Return to Tuning discussions
