Hi ,
I am wondering on how far fuel temperature can make tolerance on ignition timing to go a bit aggressive
Let’s assume we cool it down from 40c to 5c
A pump gas 98 octane
Stephen Dean wrote:Hi Victor,
Which ECU are you using?
From experience, cooling the fuel without a matching change in the default Fuel Temperature set in the ECU, will make the engine run rich, and a change from 40° to 5° will move the Lambda from around 1.00 to 0.85 at idle without any other changes. Having a Fuel Temperature sensor in an M1 will compensate for this.
When it comes to Ignition control, there will be an effect, but not as much. There are a lot of variables in play when it comes to Ignition advance, so whilst having more charge cooling can assist, having a denser mix in the combustion chamber can increase the dynamic compression ratio and increase to possibility of an abnormal ignition event occurring.
