Dual intake engines
Ive got an interesting question....
If you have a V engine and you separate the 2 banks as far as inlet goes and you have an M800......(having 1 throttle per bank)
1. Would you exclude MAP comp/measurement completely?
2. Would you T the MAP sensor to read the avg of the 2 banks?
3. Would you Run 2 Map sensors each feeding into the INDV fuel tables to trim from MAP reading for the individual banks? (cylinders)
