Question about weak spark
Hello
I'm suspecting my ignition coil to be faulty
The spark is purple, is that normal ?
My timing light doesn't flash at every RPM, is that normal ?
I have been "tuning" my engine without lambda sensor for years and i had no ignition problems.
After adding a lambda sensor, i realized that previous mixtures were very lean, so i corrected that.
Now, my engine works better but i have misfires sometimes (sometimes it stops the engine instantaneously). It happens very randomly
I'd like to know if a weak spark can be sufficient with a lean mixture but not with a rich one ?
